Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 01-09-2007, 03:33 PM
ed wheeler ed wheeler is offline
hard starting 94 maxima
The only way I can start my maxima is by pushing down on the gas . I have changed all injectors and still have problem . It just started getting worse and worse. Also I noticed when it turns over it will just stop cranking and I have to tap ignition for 5 minutes to get it to turn over again. Almost like the cylinder was filled with gas and stops the piston instantly. Now engine check lite is on and it runs a little rough . Please help!!!
Old 01-10-2007, 12:34 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: hard starting 94 maxima
VG or VE engine? Fuel pressure - is what?
Read all 25 pages, clic link below
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 01-25-2008, 12:44 AM
swiftknight23 swiftknight23 is offline
also when trying to start an engine, that puts a lot of strain on the battery, if you keep turning and turning and turning, you consicently drain part of the battery, this could be part of the problem, it may also be a clogged air filter. some of your sensors might be starting to fail. (eg) bad electronic sensor, a bad mass air flow sensor, ect.
Hope this helps
Terrell
