Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-09-2007, 12:25 PM
klvaleri klvaleri is offline
1999 Rodeo 3.2L
My starter is on the last leg right now. I am going to replace it this weekend. Is any members have any suggestions on how to replace this starter? I have not done this before. I need all of the helps I can. Thanks in advance.
Old 01-09-2007, 12:46 PM
Cat Fuzz Cat Fuzz is offline
Re: 1999 Rodeo 3.2L
When replacing the starter the exhaust will be in your way. There are several ways around this. Some will disassemble the starter to get it in and out. Others unbolt the engine from the mounts and lift the engine to gain access. I think the best method is to remove the Y-pipe. The only possible snag here is that you risk breaking the studs that hold the pipe to the manifold. Get yourself some PB Blaster (not WD-40) and spray that stuff on the exhaust bolts repeatedly and let it soak in overnight or longer. Hopefully this will allow you to remove the y-pipe without breaking anything.
Old 01-09-2007, 02:09 PM
surferfletch surferfletch is offline
Re: 1999 Rodeo 3.2L
That's if you have 4x4. 4x2 is easier. No exhaust troubles, I believe.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 01-09-2007, 02:19 PM
Re: 1999 Rodeo 3.2L
Where can I buy this PB Blaster at? I had V6 3.2L 4x4. Thanks.
1999 RODEO LSE 4WD V6 3.2L
Old 01-09-2007, 06:54 PM
Re: 1999 Rodeo 3.2L
Advance Auto has it. It's a pentrating oil.
Old 01-09-2007, 07:03 PM
trooperbc's Avatar
trooperbc trooperbc is offline
Re: 1999 Rodeo 3.2L
like Liquid Wrench, except many like it better.
it worked for me. but so does liquid wrench.
whatever you can get. just do it early and often
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 01-11-2007, 03:39 PM
Re: 1999 Rodeo 3.2L
Is any body has some kind of pictures where it locate at and how to removing and installing this starter. I am going to work on it this Saturday and need all the helps from your guys. Thanks.
Old 01-11-2007, 05:58 PM
trooperbc's Avatar
Re: 1999 Rodeo 3.2L
are you saying you don't know what the starter looks like, or where it is on your rodeo?
if so, you might want to get a repair manual, even chilton's or haynes, or factory
www.helminc.com or online www.alldata.com so you at least get orientated...
//bc
Old 01-12-2007, 06:56 AM
Re: 1999 Rodeo 3.2L
//bc
trooperbc,
Never mind, I got it now. Thanks any way.
