Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 01-08-2007, 07:34 PM
PROV1 PROV1 is offline
A/C Noise
The a/c clutch on my car is making noise like a bearing going out. If I spray it with water it momentarily relieves the noise. Can I replace the clutch only, or do I have to replace the whole unit? This vehicle is a '97. Do I need to buy a new clutch or do you think it's safe to ebay a whole assembly then remove the clutch? Is the clutch easily removed without loss of freon while still on car? Do I have to have a special tool to remove the clutch?
A lot of questions so any help would be appreciated.
Old 01-08-2007, 07:42 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: A/C Noise
Your local parts place should have a clutch and hub for it.
Yes you can change clutch and bearing with lose of gas.
But you will need a couple of removal and install tools.
Which some parts places like auto zone will rent or loan.
MT
Old 01-08-2007, 10:29 PM
Re: A/C Noise
Thanks for the reply. I'll be tackling this job real soon. Ill probably be going with a new replacement part.
