Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-08-2007, 04:46 PM
noholdsbarred noholdsbarred is offline
Question What else could it be?
Alright, this problem has been occuring for the last little while. When I shift gears quickly, mainly from first to second, I hear this clunking sound coming from the rear of the car. If I ease it into second, it is not so bad. I found that the front u-joint was loose and had that replaced, but it kept happening. Next time I took it in I was told the rear u-joint and both driveshaft hangers were bad. So $500 later, it is still happening. I'm baffled. What else is back there that could be clunking around? Oh, forgot to mention, when the car rolls backwards in neutral, it makes a small sound even before the car starts moving forward. I'd appreciate any help you can give me.
2004 Impreza WRX
Old 01-08-2007, 05:17 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: What else could it be?
They charged you 500 dollars to replace driveshaft hangers? Sorry dude but you need to find a new mechanic.
If you have a noise coming from the real of the car when you shift. I would assume that it's your Rear differential. It's the only thing that I could see making any noise when you are shifting, atleast coming from the rear of the car.
1991 GSX 2.3 Stroker
