Old 01-08-2007, 04:07 PM
bigstakz bigstakz is offline
Unhappy ABS/Trac Off
Hey Guys! Ok here's another problem. Two days ago while on the way to work, I hit a huge pot hole (Miami). My ABS and Trac light immediately came on. I seriously hope that something only came loose. Please any possible answers are accepted.
2001 Pontiac Grand Prix SE 3.1 V6
2000 Chrysler Concorde LXi
Old 01-09-2007, 03:58 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: ABS/Trac Off
Most likely a bad hub which contains the wheel sensor. Also, check the electrical connectors to each wheel sensor and make sure they are tight and inspect the wiring harness to each sensor and look for cuts or fraying.
Timeslip 08/12/06
AF Community Guidelines
Old 01-10-2007, 04:03 PM
Re: ABS/Trac Off
Thats what I thought and hoped for. Thanks again
Old 01-25-2007, 10:45 AM
Re: ABS/Trac Off
My connection on the passenger side was completely broken in half. The hub wire is fine but the wire running from the car the connecting end was broken. Any estimates on repair?
Old 01-25-2007, 02:08 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: ABS/Trac Off
There is a service bulletin on that issue that suggests replacing the entire harness rather than splicing a new connector in there (GM service bulletin# 03-05-28-008). The harnesses are GM dealer only and are as follows.
driver side: 10340317 (dealer retail $43.28)
pass side: 10340315 (dealer retail $41.05)
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 02-07-2007, 07:53 PM
Re: ABS/Trac Off
It really seems like this is a very common problem amongst us loyal GP owners.
Old 02-08-2007, 11:20 AM
Re: ABS/Trac Off
Could the bad connection cause the SES light to come on?
