Old 09-24-2002, 12:02 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
ignition upgrades
Ok i need everyones opinion on ignition upgrades. Msd, Crane or holleys Annihilator.Whats good, what sucks whatever...
thanx alot guys(and girl(Ami))
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 09-24-2002, 12:37 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
I've heard alot of good stuff about MSD, which is why I'm going that route... Full MSD setup would probably cost you around $200 if you hunt around for good deals (MSD ignition control, MSD Blaster 2 Coil, MSD modified distributor cap).
Old 09-24-2002, 12:57 AM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
I went all MSD. I got he MSD SCI ignition controller, MSD blaster coil, and the MSD modified dizzy cap. I definately felt alot smoother ride in the higher rpm
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 09-24-2002, 01:04 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Well i heard lots of good stuff on electromotive but expensive...
Old 09-24-2002, 09:44 AM
gunnmen01's Avatar
MSd 6al box? Is that what i need?
Old 09-24-2002, 05:54 PM
ci5ic's Avatar
The 6A is the basic MSD ignition. The 6AL has a built in adjustable rev-limiter... If you want the rev-limiter, go with the 6AL, but if not, the 6A would be just fine.
The 6T is mainly for off-road or high-vibration extreme conditions operation.
The 6BTM is for forced induction engines and includes a control for retarding the timing up to 3°.
As far as the other stuff you need:
Modified distributor cap (part number: MSD-8290)
MSD Blaster, Blaster 2, or Blaster 3 Coil
Old 09-24-2002, 07:02 PM
gunnmen01's Avatar
Hey thanks ci5ic that the answer i was waiting for...
gunnmen01
Old 09-25-2002, 01:42 AM
BullShifter's Avatar
I have the MSD set-up including SCI w/ rev limit box, High-vibration coil(can be mounted in ANY posistion unlike others on the market), modified distrib. cap w/ external coil hook-up, & 8.5mm SC wires. The controller box requires cutting & splicing wires in & out side of the cap. Very simple hook for all parts. I have some pics of the finsihed install but need to scan them & shit. soon i will post a few.
Accel makes a kit that requires no cutting/spicing of any wires. Every thing comes with connection to fit OEM parts. Seems like a simple install. Do know of any one w/ that set-up
Old 09-25-2002, 03:48 AM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
msd kicks ass... it was close to 300 with the box, the coil the cap and the wires, but it made starting a lot easier and smoother, the engine ran smoother over all + slight gas milage increases... but it def. looks hella cool in the engine bay too though
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 09-25-2002, 04:41 PM
i have the box & coil hidden from view. box is installed behind the glove box & the coil is mounted under the CAI tube. only down side of having the box inside the car is the noise.
Ignition upgrade for nitrous CRX mrchris1979 Forced Induction 22 02-19-2004 02:14 PM
Ignition upgrade or not.......... lildaddy29 Engineering/ Technical 4 10-03-2003 10:43 PM
ignition upgrade hondata Engineering/ Technical 2 08-07-2003 01:52 AM
Ignition upgrade? tartan Integra 3 03-08-2002 10:13 AM
4th gen ignition upgrade!?!?!? ShockJon Engineering/ Technical 2 01-26-2002 10:42 PM
