Old 01-08-2007, 01:00 PM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
need to know torque specs????
hey guys..i need to know my torque specs for the head bolts..if it makes a diff..its a sohc..
Old 01-08-2007, 01:52 PM
Igovert500's Avatar
blue + red light magnet
Re: need to know torque specs????
Don't have manual with me, but I believe ~90ft/lbs. And I know you have to tighten and loosen then retighten, etc, in 3 stages to get them right. Although I don't know the exact method off the top of my head.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 01-08-2007, 02:27 PM
i see..well there have been conflicting arguments about what it is..if you have the manual can you please look it up? i dont have a manual..if anyone knows exactly what it is and what the 3 stage method is..please let me know..thanks..
Old 01-08-2007, 02:29 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
photobucket is slow, so i'm having trouble uploading the pic from the manual. basically, for a non-turbo DOHC engine, the torque spec is 80 ft-lbs. for Turbos, the torque 90 ft-lbs
(1) tighten in "two to three stages in the illustrated sequence.
(2) back the bolts off once (or twice) and tighten them to the specified torque in the same procedure as shown in step (1).
intake
| 8 4 1 5 |
| 7 3 2 6 |
exhaust
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 01-08-2007, 02:31 PM
i have a sohc though..is there a difference?
Old 01-08-2007, 02:47 PM
Linebckr49's Avatar
i didn't include the SOHC specs in the cut&paste pic below, but i checked the manual, and the tq spec for the SOHC head bolts is 80 ft-lbs. apparently, you don't have to tighten, back off, tighten the head bolts for the non-turbo motors. however, if you want to do it in 2 stages, you can. it can't hurt.
93 3000GT base
Old 01-08-2007, 08:57 PM
sLADe781 sLADe781 is offline
Why would you have to tighten, untighten, tighten, untighten, etc etc? What does it do that a regular tightening wouldn't do!?! Sorry if it's a stupid question... Hehe
Old 01-08-2007, 10:13 PM
Igovert500's Avatar
It covers the chance of anything stretching/shrinking, etc. If the last few threads stretch or if tey bite into the metal etc. It ensures that they end up at say 80ft/lbs instead of say 75ft/lbs. At least that is how I've always understood it. I know I read something a few years ago about how if just tightened down to spec the first time, it can be a few ft/lbs less than spec. Plus by backing them out in that order, and retightening them, you ensure a completely flat seal, because you don't want a head gasket leak later on. That is basically the reasoning behind it that I've always heard.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Linebckr49's Avatar
all i can say is "that's what the manual says."
i can only speculate that the tighten-loosen-tighten process better ensures a complete seal the 2nd time it is tightened. also, note that there is a special sequence in which you should tighten the bolts. this sequence traces the path of an outgoing spiral. namely, the head must be tightened from the inside out.
93 3000GT base
