Go Back   Automotive Forums Car Chat > Mitsubishi > Mirage
Old 01-08-2007, 12:12 PM
tha_mann tha_mann is offline
Wont start!!!
I have a 95 Mirage that last week it started, and know it want. It just keep turning over. Checked timing belt and it has gas. Need a little help.
Old 01-09-2007, 07:59 AM
DFBonnett DFBonnett is offline
Re: Wont start!!!
Does it try to start at all? Are you getting spark? Have you checked the fuse(s) for the injectors? Have you tried removing the air cleaner element and giving it a spray of starting fluid through the intake?
Old 05-08-2007, 07:33 AM
vetter852002 vetter852002 is offline
Smile Re: Wont start!!!
i jus had the same problem..i replaced the fuel pump & filter..ecm..checked all the fuses and it was firing..stalled a few times before it completly died..turned out it was the coil wasnt putting out enough juice ta keep it runnin an finally got so weak it wouldnt start anymore..but if u pull a plug out it still had spark..replaced the whole distributor (coil is in the distributor) at a junk yard for 35$ fixed the problem an starts and runs great now an hasnt stalled...hope this helps
