Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-08-2007, 09:28 AM
joelin joelin is offline
Question Isuzu Rodeo 2000 6V 3.2L Faulty Codes
I have Isuzu rodeo 2000 4x4 6 cylinder and I want to know how can I repair the this code ::::
#PO401 Engine flow insufficient: I already clean the EGR valve with one can of intake cleaner
But this one I dont know
#PO300 Random/ Multiple: Cylinder Misfire
Old 01-08-2007, 12:17 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Isuzu Rodeo 2000 6V 3.2L Faulty Codes
Does the pintle on the EGR move up and down? Did you clean the EGR tube?
What brand of plug do you have in the truck?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-08-2007, 02:18 PM
Cat Fuzz Cat Fuzz is offline
A new set of plugs and wires will usually fix a p0300 code. Unless you have coil-on-plug in which case just plugs.
Old 01-10-2007, 06:55 AM
Yes,PO#401 cleanthe EGR valve w/intake cleaner and now the pin move up and down but I disconnect neg. battery for ½ hour went to Inspection and code still there.
What its the best Spak plug wire are you recommend me???????
Isuzu Rodeo 2000 3.2L
Old 01-10-2007, 07:54 AM
Isuzu Guy
http://isuzufaq.ibctech.ca/#faq15
-Ryan
Isuzu Moderator
Car Show Tips
Old 01-10-2007, 07:12 PM
Ramblin Fever Ramblin Fever is offline
You'll need to REALLY clean that EGR, like 4-5 times probably depending how bad it is and if your over 80k without ever having cleaned it, you can bet it's REAL dirty. Clean the valve AND the EGR tube.
Also clean your throttle body.
I don't suggest just buying a new EGR valve as that generally does not solve the problem.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
