Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 01-08-2007, 03:17 AM
swk9 swk9 is offline
Disconnecting factory alarm
Is there a simple way to disconnect the Factory alarm on a 1994 Continental? The alarm every so often goes off for no apparent reason, and my family really does not need the alarm, so rather than deal with something we don't need I figure we should have it disconnected. Any feedback would be appreciated.
Thanks
Old 01-09-2007, 04:37 PM
Towncar's Avatar
Towncar Towncar is offline
Re: Disconnecting factory alarm
I can't say what will happen once this module is removed, but I suspect the car wont operate any longer
«1994 Continental Table of Contents»
«Group 13: INSTRUMENTATION AND WARNING SYSTEMS»
«Section 13-11: Anti-Theft Alarm System»
«REMOVAL AND INSTALLATION»
Anti-Theft Alarm Control
Removal and Installation
1. Disconnect battery ground cable.
2. Open the luggage compartment door.
3. Remove luggage compartment front trim cover.
4. Remove two screws retaining anti-theft alarm control to RH side relay panel. Remove anti-theft alarm control.
5. Disconnect electrical connectors from anti-theft alarm control.
6. To install, reverse Removal procedure.
PS This may interest you as well:
Fuses, In-Line
There are two in-line fuses located inside the luggage compartment leading from the alarm relay. To replace, disconnect the battery ground cable. Separate the in-line fuse holder and remove the fuse. Replace with the same type fuse. Connect the fuse holder and connect the battery ground cable. Check system operation.
-Steven
1996 Town Car, Cartier
Old 01-09-2007, 06:03 PM
Towncar's Avatar
Additionally, you may find these handy:
-Steven
