Go Back   Automotive Forums Car Chat > Pontiac > Grand AM > Tips and Maintenance
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-07-2007, 11:12 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Thumbs up Coolant Temp Sensor on 99+ Grand Am Testing
This works on 99'+ N-Bodies,
but is relevant to most N body temp sensors vs. resistance values.
Heres a pic of the coolant temp sensor,
and it located right under the TB on the V6(3.1 & 3.4L) easy to see and get to.
Easy to locate on the 4cyl(2.4L) too.
V6 temp sensor
4 Cyl Temp sensor
Testing your Coolant temp sensor is as follows;
- First inspect the wires at the plug for looseness or breaks.
- Now test the circuit for power from the PCM.
- Disconnect the plug-in on the sensor and test the two terminals on the wire harness.
- Connect the + lead on the voltmeter to #1 and the ground to #2.
- Turn the key on, should read approx 5 volts.
- If not check the wiring from the plug to the pcm.
- If the cicuits are good have the PCM checked by a dealership or other qualified shop.
Checking the resistance values
- With the ignition off and engine cold, unplug the sensor connector.
- Using an Ohmmeter measure the resistance between the terminals on the sensor cold(between 50-80 deg). Write that # down.
- Start the engine and let it get to running temp between 180-200deg.
- Disconnect the connector and test the resistance again.
- Compare the two measurments to the chart below.
- If the results are incorrect then replace the sensor.
- When replacing the sensor use teflon tape to seal from leaks.
Hope that helps.
1999 Grand Am SS 3.4 OHV
The Following User Says Thank You to xeroinfinity For This Useful Post:
jerryhunt92284 (07-19-2011)
Closed Thread
