Go Back   Automotive Forums Car Chat > Chevrolet > Corsica
Old 01-07-2007, 10:12 PM
carpoop carpoop is offline
94 Corsica/Where is codes located to read
I am locating codes for 94 Corsica. Where is this located?
Old 01-08-2007, 09:47 PM
jsgold jsgold is offline
Re: 94 Corsica/Where is codes located to read
Are you asking how to check? Or, what codes are there listed so you can d/c? You can do the first using a paper clip, although I don't do that myself. Can buy a plug in checker with a code book at most local parts stores for less than 35 bucks. Many parts stores will check for free but since yours is OBD1 some might not have a tester fort this, as cars made after 94 are mostly OBDII types. From your other post it sounds like you are trying to see what codes are stored in your recently repaired and locked up 94. I do not remember which connectors you short, if you short the right two the check engine light will flash a number of times, 12 first (shows computer OK) then other codes will set as it should flash the codes twice each time, just count the flashes. I would bet a sensor is unplugged or you have a bad vacuum leak, or, major transmission woes. Some one here should be able to get you lined out on the procedure to obtain codes, and there are various places to check the codes once obtained, like here, or, corsica web sites etc.
I used to be indecisive, now I am not so sure.
Old 01-08-2007, 09:55 PM
Just a thought, you might be able to borrow a code checker from Advance Parts as they do lease and loan certain tools. If you know any other mechanics perhaps they can loan you one. Good luck.
