Old 01-07-2007, 09:41 PM
PlayStation3 PlayStation3 is offline
grounding
hi, i was wondering if i could just use an "existing" seatbelt bolt for the ground in wire up my amp.
Old 01-07-2007, 10:44 PM
jtvyper456's Avatar
jtvyper456 jtvyper456 is offline
Send a message via AIM to jtvyper456
Re: grounding
You could, thats what I did, but it caused me a heck of a lot of trouble...after about 3 weeks, the amp quit working, it would get a small amount of power, and then die out, moved the ground, and it works perfectly.
1995 Camaro
40 Series Flowmaster
2 Kicker Comp 05CVR 122 (Dual 2Ohm Voice Coils)
^Kicker ZX550.2 Amplifier^
Old 01-07-2007, 10:46 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: grounding
Anything can be used for a ground as long as you file or sand the paint of below the bolt to make a good ground, ive used the bolt for the trunk latch, seat belt bolts, and the seat mount bolts.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 01-08-2007, 05:24 AM
vinnym86's Avatar
vinnym86 vinnym86 is offline
Send a message via AIM to vinnym86
Re: grounding
remember to keep the ground wire as short as possible, i'd say under 3 feet.
The most beautiful thing we can experience is the mysterious... He to whom this emotion is a stranger, who can no longer pause to wonder and stand to rapt in awe, is as good as dead: his eyes are closed.
Old 01-08-2007, 06:13 AM
Re: grounding
i only have 3 feetof cable so no problems there. and the amp is going on the back of my foldable back seats
Old 01-08-2007, 11:18 AM
Re: grounding
Damn 3 feet i was always told no longer than 12", i try to keep them between 6-8" if possible.
Cardomain
Old 01-08-2007, 12:42 PM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: grounding
i don't think it makes much of a difference as long as the cable is thick enough, but shorter is better.
x2 on sanding the paint off. get it nice and shiny so it makes good contact.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 01-08-2007, 01:52 PM
Re: grounding
should i use contact cleaner on it, after i sand it down.
Old 01-08-2007, 02:06 PM
Re: grounding
Id just say make sure its clean rubbing alcohol works good.
Cardomain
Old 01-08-2007, 02:17 PM
Lefix's Avatar
Lefix Lefix is offline
Send a message via MSN to Lefix
Re: grounding
Yeah I used the bolt that is under the seat, i sanded it and it works great...
My CarDomain
Boost coming soon...
Old 01-08-2007, 05:31 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: grounding
shorter tends to be better (when it comes to ground wires)
Old 01-08-2007, 06:52 PM
vinnym86's Avatar
Re: grounding
less chance for loopback distortion.
Old 01-08-2007, 07:05 PM
Re: grounding
don't they make some sort of filter to get rid of that though?
Old 01-08-2007, 07:16 PM
SlackerOfSociety's Avatar
SlackerOfSociety SlackerOfSociety is offline
Re: grounding
i have a question, could unproper grounding cause your battery to drain faster?
Old 01-08-2007, 09:20 PM
jtvyper456's Avatar
Re: grounding
Inproper grounding could make your amp quit working, not sure about the draining the battery, but it's potentially dangers to your amp.
1995 Camaro
