Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-07-2007, 09:12 PM
JAY56 JAY56 is offline
Dashboard Lighting Out
Need Help!!! My Lighting In Dashboard Went Out Needed To Know If It Is A Fuse And If So Where Is That Fuse Located Please Help!! 1992 FORD EXPLORER pretty much everything on the dash that is able to be dim.
Old 01-08-2007, 02:25 PM
Dr98 Dr98 is offline
Re: Dashboard Lighting Out
Okay,
To start with the basic stuff. Make one post for your topic. Put your post title as " Need Help urgently, my dash lights are out".
Next specifics of your vehicle model year, etc.
Go here to download your owners manual- https://www.fleet.ford.com/maintenan...ls/default.asp
Then check your fuse panel inside the truck.
Edit- I just noticed the link I gave above, doesn't have owners manual for 1995 and earlier. Sorry about that.
Dr98
Old 02-08-2007, 01:53 AM
poormans96exploder poormans96exploder is offline
I just replaced all of the dash lights in my 96 explorer, and it is no fun at all. You need to literally start on the trim under the dash and work your way up, as well as possibly taking out the entire radio assembly area to get the hidden screw behind the dash trim. The lights were expensive (about6-8$ a pack) but replace all of them because it takes quite a while to do so. Also, you will need several different sockets and such to get your way up!
Old 02-08-2007, 06:54 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Look at the fuse panel under the dash. There should be a 10 amp fuse in position 13. This is what gives current to the dash. Check it to be sure it is not blown.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 02-08-2007, 12:39 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Are the lights for the radio button backlights, door lock and power window switches, etc. also out, or only the ones in the instrument cluster? I know you typed "dashboard" but just want to make sure that's what you meant.
-Rod
Old 02-10-2007, 06:48 AM
Kaobb Kaobb is offline
This sounds pretty crazy and you have probably already done it but...... make sure the "thumb wheel" for dashboard brightness is not turned off. I had this happen to me once either my kids were messing with it or the guys at the car wash accidentally turned it off while cleaning the interior.
I believe the Germans call this the "einstellung' effect (People may become biased by experience to prefer certain approaches to a problem, which may block the solution in a particular case — the einstellung effect ....)
A related short story.... one day this guy noticed his shower would not drain. He used drain un-clogger stuff etc. Nothing worked. So, he decided to tear into it a repair the pipes. He had ripped into it pretty good when all the sudden he looked down and noticed the little lever that controls the drain hole of the tub and it was three-quarters pulled in the plug drain position. Viola.... the root cause of the problem.
Anyway, good luck fixing your lights....
K
BTW_ Rod is one of the best fix-it guys I know!
Old 02-25-2007, 07:01 PM
Wanababoardr Wanababoardr is offline
I have a 95 Ford Explorer which i love to death. Recently while heading up to go snowboarding I noticed the left side of my instrument cluster went out, then came back and then back out again. Gotta love Fords right?
How much work am i gonna have to do to replace that light? Should i just replace all of them once i get her opened up?
