Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-07-2007, 07:42 PM
ynghank ynghank is offline
Unhappy Tapping noise after turning off the car
Almost every time I turn off my 95' I hear a loud tapping or popping coming from under the hood, i can feel it in the accelerator pedal. It taps about 6 to 8 times and happen's about every two to three shutoffs. I look around on the forum and couldn't find any similar threads, Is this familiar to anyone?
Old 01-09-2007, 09:35 PM
apollo7879 apollo7879 is offline
Re: Tapping noise after turning off the car
Could be the throttle position sensor trying to calibrate itself.
Remove the MAF sensor assembly & clean the throttle body of any contaminants that may be restricting the throttle plate.
Be sure to put the MAF back on exactly as you took it off, also careful not
to damage the screen as this could affect airflow.
Then perform the throttle position learn procedure as follows:
Turn the ignition sw to on with the engine not running
Wait 30 seconds
Turn the ignition sw to the lock position
Wait 30 seconds
Calibration complete
Don't know if this is your problem but its worth trying.
Old 01-10-2007, 06:20 AM
Thanks for the advice I'll give it shot.
Old 01-17-2007, 08:10 PM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
could be the exhaust cooling down
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 01-17-2007, 08:12 PM
especially if its cold outside
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
