Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 01-07-2007, 05:58 PM
Travisty3 Travisty3 is offline
1996 Mustang GT throttle body Spacer install.
I am trying to install a throttle body spacer on my 1996 mustang GT. I can not figure out how the throttle cables connect up with the small plates and the screws. Please help !!!
Old 01-11-2007, 03:20 PM
6speed's Avatar
6speed 6speed is offline
Re: 1996 Mustang GT throttle body Spacer install.
do you mean the intake spacer? ive never heard of someone making throttle body spacers. if it is a t/b spacer its just four screws around the outside then the wire coming from the side farthest from you clips into the bottom area to open the butterfly
07 jeep cherokee srt8
99 saleen s281
05 cbr 1000rr
Old 01-12-2007, 12:04 PM
It is a spacer that fits between the t/b and the intake. I purchased it off of ebay about a year ago. After I tried to install it I found that the gaskets were labeled for a Ford F150. I did some more checking around on the net and found a pic. for the one I need. The spacer seems to be the same but the extenders for the throttle cables are different.I do not know if I can purchase just the cable extenders. Thanks for taking the time to try to help me.If you know of a site I can order just the extenders please help. Thank you again.
Old 01-12-2007, 12:06 PM
neatofrito1618 neatofrito1618 is offline
Send a message via AIM to neatofrito1618 Send a message via Yahoo to neatofrito1618
TB spacers don't do anything.
Old 01-12-2007, 02:05 PM
I just installed a turbonator but I had to trim it down so small for it to fit that I think it is restricting my air flow. Car idles rough and knocks bad. I will check here before I waste any more money on CHEAP upgrades. Thanks for the help.
Old 01-13-2007, 10:39 AM
mustangman02232 mustangman02232 is offline
Send a message via AIM to mustangman02232 Send a message via MSN to mustangman02232 Send a message via Yahoo to mustangman02232
turbonator, tornado, TB spacers, CAIs they all are waste of money
2004 F350 6.0 4x4 auto SRW
SCT X3 with innovative tunes, autometer boost/trans/pyro, AFE stage 2, MBRP 4" no muffler or cat, EGR delete, ARP studs, 8' fisher MM2, misc appearance
90 F350 7.3 IDI 4x4 SRW (sold)
bolt on 02 mustang 232 4R70W vert (sold)
built 88 toyota pickup (sold)
bolt on 92 camaro LO3 TBI (sold)
Old 01-13-2007, 11:15 AM
Scrapper Scrapper is offline
AF Premium User
Exclamation Re: 1996 Mustang GT throttle body Spacer install.
you only have a gasket and 4 bolt holes.you are waisting your time and money..
Old 01-13-2007, 12:05 PM
No, I have 2 gaskets, spacer, and 3or4 cable extenders. But the cable extenders are what will not fit. What are CAIs before I buy that?
Old 01-13-2007, 03:19 PM
351wStang's Avatar
351wStang 351wStang is offline
CAI is cold air intake.
1969 Cougar
357w & TKO - 475hp
Old 01-13-2007, 05:22 PM
Why is CAI a waste of money?
Old 01-13-2007, 10:40 PM
72' Stang 351 H/O's Avatar
72' Stang 351 H/O 72' Stang 351 H/O is offline
CAI's are worth very little if you plan not to build the engine. It will add power if you do some upgrades, but not much. They are better for T/C applications.
Old 01-13-2007, 10:57 PM
The expensive name brand ones are, they cost a lot and you don't gain much power. But the Ebay ones aren't bad, for how cheap they are they're a pretty cost effective mod.
Old 01-14-2007, 04:35 AM
Thanks, I might mess around here and yall might teach me something.
Old 01-15-2007, 03:07 PM
they add 2 HP, you get the same results from droping in a K&N filter and triming the air silencer
Old 01-17-2007, 01:55 PM
6speed's Avatar
my god, id take that off and throw it away before it does more harm than good.
intake spacers, as seen here:
http://cgi.ebay.com/ebaymotors/96-04...spagenameZWDVW
has been proven to add a few ponies, throttle body spacers on the other hand ive never heard of. if you want to add some power without wasting your money try some of these:
steeda underdrive pullies
steeda timing adjustor
c&l (or other brands, accufab, etc) throttle body & plenum package
exhaust goodies(off road midpipe if possible)
a CAI is more for looks than horsepower as the stock setup is not restrictive and there is little to be gained 1 or 2 hp isnt even going to be noticeable. however, if you were running a supercharger or something else of the sort to make huge hp, the hp numbers of course increase in parallel
99 saleen s281
05 cbr 1000rr
