Fuel pump location '97GT and Fuel Pressure
Where is access to the fuel pump on a '97GT? I know some have access from the trunk area but I can't see it on mine. I suppose it is necessary to drop the tank to gain access.
97 Grand Prix GT 360,000 miles as of 02-01-09 391 000 miles as of 11-17-11 400,000 miles as of 3-15-13 01 Duramax/Allison 07 G6 convertible |
Re: Fuel pump location '97GT
It should be in the trunk area behind the rear passenger seat. Did you move the carpeting out of the way? Then look for an access cover with 7 nuts securing it.
I didn't get back that far but will check it this afternoon. Car will only fire off momentarily and pump is making a funny noise. After 320,000 miles, I guess it's about time it quit on me. I suppose the first thing to check would be the fuel pressure and if it's low then the pump would be suspect.
If it tests within specs, what would be the next thing to check?
Fuel pressure check would be a good idea. How old is the fuel filter? Wow, 320K miles now.
Yesterday morning it just wouldn't crank. Almost fires off and I can hear the fuel pump making a noise. Seems to be some pressure when I push on the schrader valve as some gas comes out.
The only way to really tell is hookup an automotive fuel pressure tester. Also, check the fuel pressure regulator and make sure diaphragm is not ruptured. You may see fuel in the vaccum line attached to it. But a fuel pressure test will test the FRP too. Good luck.
Fuel pressure test
Bought an Actron fuel pressure tester and connected to the schrader valve on what I assume is the regulator. I cut off the AC. I turn on the ingition and hear the pump making a noise. During the cranking cycle, I only get about maybe 5 lbs of pressure. It barely moves the hand, but a little.
So I assume the fuel pump or regulator is bad. Any way to tell which one? My guess would be the pump since the car has 320,000 miles on it. '97 GPGT
Re: Fuel pressure test
It would be the pump. Did you check it with key on and engine off-What do you get then?
I noticed a time or two in the last couple of weeks that it was just a little slow to start up.
Most likely it is the pump. Sometimes you can smack the tank while cranking and they will temporarily come back to life. Also the fuel pressure regulator is the part with the small vacuum hose going to it. Make sure it is not leaking gas into the hose. The schrader valve is actually part of the fuel rail assembly. Make sure you also look at the wiring to the pump. Good Luck!
Removed by Moderator |
wlkjr,
Your two threads have been merged. In the future please try to keep the same or a similar issue in a single post to avoid confusion and redundant answers.
Re: Fuel pump location '97GT and Fuel Pressure
Are quick disconnect tools required to remove the hoses from the pump? Any hints about how to get the pump loose and out of the hole?
![]() Arrow points to the C-Clip Retainer
Thanks Bob. I've already opened up the cover and removed the electrical connector, I only have one. It was quite dusty and dirty so I blew out all the dirt with an air hose. Waiting for my new pump to arrive. Sounds like maybe a 30 minute job.
BTW - When you install the pump make sure it is centered just right over the hole and press down to load the springs before installing the c-clip. If the c-clip is hard to install it will be because the unit is not centered just right. Silicone lube or Vaseline on the o-ring seal helps too. Good luck and sounds like it is in good hands.
