Old 01-07-2007, 04:02 PM
TGENERAL TGENERAL is offline
Engine dies when coming to stop
My 91 was having trouble with pcv valve. I was getting oil back up in the air filter. This problem has been fixed but seems to have caused another. Now when I kick it out of gear coming to a stop sometimes the engine dies. I see the oil light come on just before it dies. It always starts right back up. What can I do to fix this issue? It did not die before I replaced the pcv valve.
Old 01-07-2007, 09:26 PM
mechhound mechhound is offline
Re: Engine dies when coming to stop
Why do you kick it out of gear when coming to a stop? Or do you have a manual tranny and when you step on the clutch, is that what you mean by kicking it out of gear? On to your problem, I would put a full container of a name brand fuel injector cleaner in a full tank of gas and hope that fixes the stalling problem.
Old 01-07-2007, 10:24 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
First, check your oil. That light should only come on if the level is low.
Usually when the engine dies like that I have found it to be a vacuum problem.
Do you have an acceleration problem? Try to speed up quickly and see if it is sluggish at all.
Old 01-07-2007, 11:00 PM
12Ounce 12Ounce is offline
I agree with checking for a vacuum leak. You may have knocked a hose loose.
The oil pressure light coming on is just probably the result of very low rpm just before snuffing out.
Old 01-08-2007, 02:38 PM
I just changed the oil so it's not that. I will check the hoses. It seems to be an intermittant problem. It only happens every once and a while. The car accelerates well (for a 1.9 4 cylinder).
Old 01-19-2007, 08:43 AM
burban12 burban12 is offline
TGENERAL - How did you fix your PCV issue. I am getting oil in my air filter also and when I went to replace the PCV valve they told me mine was not the typical type. I have a 1989 escort 1.9 carberated
If your clean your not having fun
Old 01-22-2007, 03:38 PM
Mine was right in the very front. I just replaced it and let the hoses hang down so the oil would drain out of them. Sorry not much help for you.
Old 01-27-2007, 02:37 PM
thehardway thehardway is offline
Question Re: Engine dies when coming to stop
If the idle control valve goes bad it will stall at every stop. It will gradually get worse until you replace it. 1 minute fix if you can find a cheep used one.
