Old 09-23-2002, 07:24 PM
dx_tuner's Avatar
dx_tuner dx_tuner is offline
Question Help Asap!!!!!!!!!!!!!!!
Ok I need help cause my car is acting up again(its really starting to piss me off). Ok my car is throwing a code 16, thats the fuel injectors right? I reset the ECU then I turn the key and the check engine light doesn't come on, then I turn it over and the car won't start then the check engine light comes on. No matter how many times I crank it, it won't start. Does any one know what it is. I just had the dist. and main relay replaced. Is there any way to fix it without having to go back to the mechanic????? or do I just need to get the injectors clean???? HELP ASAP PLEASE!!!!!!!!!!!!!!!
1989 Honda Civic HB DOHC VTEC 1.8L 07 2005
WWW.HONDA-TECH.COM
Old 09-23-2002, 07:39 PM
dx_tuner's Avatar
ANY HELP
WWW.HONDA-TECH.COM
Old 09-23-2002, 08:24 PM
dx_tuner's Avatar
HELLO IS THERE ANYONE THAT CAN HELP?????????????????????????????????
WWW.HONDA-TECH.COM
Old 09-23-2002, 09:59 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Check the connection to your starter if it doesn't crank at all.
Also do you know if you are getting fuel at all?
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 09-23-2002, 11:58 PM
dx_tuner's Avatar
ok I checked the dist and its throwing spark to all 4 cylinders. The only thing I can think of is clogged fuel pump or injectors, or the main relay. What do you think? But it does crank over
WWW.HONDA-TECH.COM
Old 09-24-2002, 01:30 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
are you getting fuel, if not replace the fuel filter.
Old 09-25-2002, 12:29 AM
dx_tuner's Avatar
My car is now running I just took the main relay off and opened it and noticed some of the solder was cracked on one of the connections so I resoldered it. And it worked. Now hopefully it won't crack again
WWW.HONDA-TECH.COM
Help Asap Help Won't Start 95 Blazer rental blazer Blazer 4 12-25-2005 05:44 AM
need help asap please help atv087 Eighty Eight 2 08-31-2005 03:17 PM
HELP, does anyone know how to connect the heat in a ford escort '88? HELP ASAP Lotus War Escort 1 06-06-2005 11:22 AM
Need Help Asap Asap Asap G35turbo 3000GT/Stealth 4 02-02-2005 10:41 AM
HELP! tail lights out need help ASAP SKiTTeR KRiTTeR Integra 2 12-14-2002 10:53 PM
