Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 01-06-2007, 09:54 PM
MPower600 MPower600 is offline
Car is making noises when it's idle and more when i turn the wheel
2002 bmw 330ci convert sport package e46:
having problems with the car and i dont have confidence in driving it. when i start the car it makes a strange noise. when i cut the wheel in place even more it makes this noise like something is hitting the fan...i'm worried and i dont want this to be a HUGEEE problem to fix at the dealership. no check engine lights are on or anything like that...any suggestions?
Old 01-07-2007, 12:28 PM
HikinTech HikinTech is offline
Re: Car is making noises when it's idle and more when i turn the wheel
Why don't you try having somebody else turn your steering wheel while you visually check under the hood for the cause of the noise. You may also have to check under the vehicle. If you have a sethoscope you might be able to pinpoint your problem.
Old 01-07-2007, 07:58 PM
i actually made it to autozone (.5mile) away...i refilled my power steering fluid and my coolant fluid. for some odd reason it was fine after that...then i realized that smoke was coming out of the front left of the car...i went back to autozone and they said i most likely have a leak in something...does anybody know if this is an easy thing to replace or atleast seal up??? thanks for the replies
Old 02-14-2007, 03:41 PM
redsox1918 redsox1918 is offline
Im having the same problem with my 1999 330. It shrieks when I turn the wheel. I checked the power steering fluid and its near dry. My bad! D'oh!. Anyway, my owners manual doesn't say what type of ATF to use for the power steering. Do you know? I'd like to get it filled, and then check it for leaks. Thanks.
Old 02-27-2007, 11:23 AM
RiCR-wana-b RiCR-wana-b is offline
Send a message via AIM to RiCR-wana-b
well there are several crucial components on that side of the motor. as some one said before, start the car open the hood and go look at where you think the leak is coming from, if its a radiator hose its simple enough to fix just a couple bucks but if its something bigger you'll be able to tell right away(usually)
30 shot of nitrous?!? what the...
thats like masterbating with your hand open!!!
Old 09-20-2007, 12:44 PM
mcalvo's Avatar
mcalvo mcalvo is offline
Send a message via MSN to mcalvo Send a message via Yahoo to mcalvo
Hidraulic oil refill?
Regards,
MC
1994 E36 320i German made. http://forums.cjb.net/bmwclubcr-about49.html
Old 02-09-2008, 08:04 PM
qtspapa qtspapa is offline
I had the same prob; changed the o ring on the fill cap, that didn't do it. the dealer wanted over $700 to replace the p. steering hoses. A frend said change the cheap clamps on the return (low press.) hoses. It worked. Less than $3.
