Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 01-06-2007, 04:49 PM
x-l-er-8 x-l-er-8 is offline
Question powermaster hydraulic brake problem..HELP!!
ok i have an 88 touring sedan. when i press the brake pedal the brake light come on and make about 15 dinging noises. i did some diagnostic work on it and came to the conclusion ti was the hydraulic pump. the pump does work if I tap or hit the font of the pump iteslf. the brake sensor is fine and the relay works also. my question is where the hell can i get a pump. the olds touring sedan isn't a very common car. i crossed refrenced some pumps but i don't know which one to use. if anyone has first hand experience on this vehicle's brake system and particular problem please help. i'm 99% sure it's the motor. is this thing rebuildable or is there some kind of kit i can buy to rebuild it?
my vehicle is an 1988 oldsmobile touring sedan with 135k on it
please someone let me know.
thanks
Old 01-06-2007, 04:56 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: powermaster hydraulic brake problem..HELP!!
To help facilitate a quicker and/or better resposne I have moved your thread/post to the Olds 88 subforum.
Also it would help to post your mileage and year.
Timeslip 08/12/06
AF Community Guidelines
Old 01-07-2007, 01:27 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Try looking for parts from a regular Olds 98 as they ought to work just fine. You should be able to get the part number off your part and use that as referencing when finding a new one. Have you tried Ebay or http://www.gmpartsdirect.com ?
As far as being able to rebuild it, its probably possible but I doubt you'll be able to find a rebuild kit.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
