Go Back   Automotive Forums Car Chat > Chevrolet > Cobalt
Old 01-06-2007, 01:17 PM
durocm durocm is offline
Replacing headlights in an 05 Cobalt LS
Does anyone know how to remove the headlight lens from the car so you can replace the headlights and turn signal bulbs on a 2005 Chevy Cobalt? I cannot get the lens out of the car to replace the bulbs.
Thanks
Old 01-06-2007, 02:35 PM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
Re: Replacing headlights in an 05 Cobalt LS
i havent had to change the bulbs on my car, but usually with a GM car you dont take the lenses off. INstead you take off the plastic piece thats above the lenses inside the engine bay. And then you remove the bulb from the back of the light.
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
-Jayson-'s Avatar
2009 Ninja 650 R
stock for now...
Old 09-24-2007, 04:22 PM
immortalengage immortalengage is offline
You actually have to remove the whole head light it self inorder to change the bulb. i upgraded mine, their should be two bolts and then you will be able to remove it. i beleve the owners manual has the step by step instructions inorder change the bulbs.
Old 09-25-2007, 07:43 PM
rodeo02 rodeo02 is offline
Yep, lift the hood and look at the tops of the head lamp assemblies. Each HL has two hex head bolts up top. Remove the bolts, lift the HL's out and then you can get the lamp holders out to swap lamps.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
