Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-06-2007, 01:09 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Red face Still with my problem. Moisture?
Hey all;
For the longest time now I've had the problem with when I'm drivning and pop to neutral, the rpms drop, then shoot back up to 2k and stay there for a while. Then when I'm rolling up to the light, it bounces 1200 - 1500 until I come to a complete stop. I believe its the EGR valve bc I've gotten CELs from it before, but haven't in a long time now.
Anywho, I noticed (since its been raining really bad the last couple days) that when it's wet like that, the problem goes away. When I shift out of gear, rpms drop right down to 800-900 and stay there. Does that sound like a EGR problem? Would moisture cause the EGR to work properly then? I've cleaned and cleaned it and it works fine, but after a while it goes back to the way it was. Again, I'm cheap and don't want to spend the money unless I need to. Gas mileage still sucks also.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-06-2007, 01:20 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Still with my problem. Moisture?
Ya know what. This is exactly the same problem I had with the Firebird... After putting a new PCV valve in, it seemed to help. Mine was so bad that it would actually stall after idle surging a few times like that. Perhaps its a similar problem? Mine is starting to do it again some but nothing like it was. Also my fuel mileage is absolutly horrible. I am gonna try the fuel filter next on mine to see if that helps the situation.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-06-2007, 02:21 PM
david-b's Avatar
Dave is THAT guy
So the PCV valve helped? Has the F-Bird ever thrown a CEL for the EGR at all? My fuel filter is brand new and clean.
75 Monte Carlo
Old 01-06-2007, 02:32 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
my eclipse does the same thing and so does my civic, not worth the effort to fix imo
I think it has more to do with coasting fuel cut, dsmlink had some settings and when I messed with those, it would change how it acted.
now - 2000 civic
soon - 2002 is300
Old 01-06-2007, 02:34 PM
The PCV valve helped and it was like 2 bucks I think? It has never thrown a CEL my way before... Knock on wood...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-06-2007, 03:56 PM
david-b's Avatar
Dave is THAT guy
I ordered one on my way home from work today. Autozone apparently doesn't carry an PCV valves in store.sad.
Anyways, I got home and pulled mine and checked it out. IIRC, I'm only supposed to be able to blow air one way through it, correct? I could do both ways. The little bar in the middle was loose, and would move around. If I pulled it all the way down, then air could only flow one way. But it I didn't keep it down, air would flow both ways. Also, there was oil in the lines. Not alot, but I don't know how much should be in there. The valve is coming in on the 10th, so hopefully that'll fix it.
Crunchy: The car never did that until up until about 6 months ago. Gas mileage took a shit and the idle has been nothing put crappy. I'm working on to see what it is and to save on some gas. And really, the valve cost $4. Can't go wrong there.
75 Monte Carlo
Old 01-06-2007, 04:42 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Honeslty I don't think your EGR valve would affect anything like that. My car doesn't even have the EGR hooked up and it's a common mod to remove it. I don't really know why you have it on your car as I thought only CA models came with it. But I could be wrong about that.
The EGR simply recirculates a fraction of the exhaust from your exhaust back into the cylinder head, about 5% to 15%. If anything I would think having it disconnected or not running would actually make the car run better.
But if you can blow through both ways on your PCV valve that is definately a problem.
1991 GSX 2.3 Stroker
Old 01-06-2007, 05:10 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Defiancy is correct, the EGR won't make your car run any worse/better, all the EGR does is recirculate a fraction of the unburned exhaust gases back into the intake mani so they can go through the combustion chamber and be burned up. PCV valves will cause some funky idles, but I don't know how badly they affect gas mileage, you might have two problems instead of just one.
95 Talon TSI AWD
97 Eclipse GST
Old 01-06-2007, 05:22 PM
david-b's Avatar
Dave is THAT guy
I have the EGR valve on bc I have emmissions here in IL. I also don't like running the car with the CEL on. I'm sure once the head is done and I go to the track, the EGR will get temperarily blocked off.
I thought EGR bc the CEL told me it was it. However, on 2 different EGRs (both valves and sensor, both used tho) I got the same CEL. Well, the PCV is going to go in and we'll see how that helps. I'm going to get to the cause of it one of these days. I'll keep you guys informed.
75 Monte Carlo
Old 01-06-2007, 09:49 PM
defiancy's Avatar
If you care is similar in emissions to mine or to turbo eclipses, if you disconnect a certain relay on there it will remove the EGR from the system without you having to actually remove it and it will not throw a CEL for it anymore. On our cars it's on the drivers side firewall in the engine bay. On yours I have no idea.
Old 01-06-2007, 09:57 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Not trying to thread jack or anything but, Why would you want to remove the EGR? is their any benefit to this? because i dont have to pass any emissions...i have my ways... and that is a fairly simple sounding mod!
Old 01-06-2007, 10:06 PM
defiancy's Avatar
Well if you take a look at it the car is dumping exhaust that has already passed through the engine back into the engine. You could remove it or simply just disable it for the following reasons. It's going to keep your intake temperature cooler due to the fact that the hot exhaust that just came out of the exhaust side of the head is not going right into your manifold and mixing with cold air.
Also your replacing cold air, with hot exhaust. If you disable it, that is more cold air that flows in there and takes the place of that exhaust that was in there before.
Because the amount of exhaust flowing into the motor isn't that great, only about 5% to 15% the mod of removing, or simply disabling your EGR is mostly to reduce the ambient air temperature of your intake.
I know, and have seen several EGR plate kits, that allow you to completely remove your EGR and replace it with a solid plate you simply screw in.
Old 01-07-2007, 12:39 AM
david-b's Avatar
Dave is THAT guy
I have one of those plates. Don't know why but I ordered one cheap long time ago and it's sitting in my closet. So there's a relay for the EGR? There's a couple on the firewall close to the drivers side. And does this garentee no CEL? I still have to block off the pipes tho too right?
75 Monte Carlo
Old 01-07-2007, 06:21 AM
defiancy's Avatar
I am no 420a expert but on the 4g63t, those relays on the firewall controll the EGR. They run a bunch of vac lines to the EGR among other things. If you disconnect those relays and vac lines there is no EGR code. I speak from experience considering my car has those disconnected and no code. I also spoke to my shop about them and they informed me of the same. I am assuming that there is an equivalent on the 420a as well.
Old 01-07-2007, 09:58 AM
david-b's Avatar
Dave is THAT guy
Cool, I will do some research and make sure those relays are the same and give it a try. Do I still need to block off the egr still? Or just by disconnecting the relays will that just stop the flow, like staying closed?
75 Monte Carlo
