Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 01-06-2007, 02:08 PM
KoDKingVegeta KoDKingVegeta is offline
Main Relay Location
Where is my main fuel relay located in my 1989 Honda Civic DX 4 dr sedan? I was told under the dash next to the fuse box. If I remove my coin holder its right there. How would I remove it?
1989 Honda Civic DX Hatchback
*STOCK
Twisted Motor Sports
The Cell Games
^--Help Revive an old forum, Come Join
-=flash to the future: (three months) "As stock prices continue to climb for superglue... ppl are frantic.... *static* KoDKingVegeta buys the whole market out *Static* fix *static* dashboard from *static* UK... *end of flash to the future*=-
Old 01-06-2007, 02:43 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Main Relay Location
I show the PGM-FI main relay.
Below left side dash above hood release lever.
Relays just pull out and plug in.
Some are a little tight so pull a little to one side and then the other.
Good Luck
MT
MT
Old 01-06-2007, 08:22 PM
Good Luck
MT
Well, I bought the WHOLE fuse thingy, lol. Then I just took the 2 relays off *didnt no if it was the small one or the big one* and put them in. And now it seems to be fine. I took it down the street and hammered on it. Brought it back and restarted it and it started *it wouldnt before* So I think Im good now.
*STOCK
The Cell Games
Old 01-06-2007, 10:38 PM
MT-2500's Avatar
AF - Advisor
Thanks for posting back how it went.
Glad you got it gong and you have some extra stuff if you need it.
Good Luck
MT
MT
Old 01-07-2007, 12:55 AM
While I was there I picked up a set of used clear bumper signels, there a little faded with a crack on one of them. But there better then the stock yellow markers.
*STOCK
The Cell Games
Old 01-09-2007, 01:55 PM
Good Luck
MT
Ok, problem. My car wont start again, its doing the same thing it did before I replaced the relay. Is it the relay? Or is it sumting else? Heres a picture of the relays in my car, could one of u tell me which one it is, so I can go out and buy a new one.
*STOCK
The Cell Games
Old 01-09-2007, 02:39 PM
MT-2500's Avatar
AF - Advisor
If you are sure it is the relay drop by your dealer parts dept and get a new one.
And match the no on old one for what one it is.
But I would do a little testing while it is in a no start mode.
Is the fuel pump firing up?
Got spark?
Got 12 volts power to injector?
MT
Old 01-09-2007, 03:13 PM
Got spark?
Just went out to the junkyard and got another 2 and it started. So I really do think its the relay. Fuel pump dose turn on, i do have spark.
*STOCK
The Cell Games
Old 01-09-2007, 04:00 PM
MT-2500's Avatar
AF - Advisor
Good luck.
MT
Old 01-09-2007, 11:45 PM
Good luck.
While, now I do no its my fuel pump. Later on in the day the car died again and wouldnt restart. So now Im going to have to replace the fuel pump.
*STOCK
The Cell Games
Old 01-10-2007, 09:44 AM
MT-2500's Avatar
AF - Advisor
Good luck.
But as said when it no start is a good time to test/check things out.
Make sure the fuel pump is getting 12 power and ground.
That main relay feeds power to it.
Saves throwing parts at it.
MT
MT
