Old 01-06-2007, 11:53 AM
Darrick147's Avatar
Darrick147 Darrick147 is offline
Send a message via AIM to Darrick147 Send a message via Yahoo to Darrick147
Sealed to Ported
A friend of mine has a sealed box that he made himself out of 3/4" MDF and he's wondering what all it would take to change his sealed box into a ported box and actually sound good.
Old 01-06-2007, 12:29 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: Sealed to Ported
Depends on whether or not he wants tube or slot port, and what the enclosures volume is. IF its to small then it wont matter how much your port it cause it would be to small.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 01-06-2007, 12:44 PM
Darrick147's Avatar
Which one sounds better?
Old 01-06-2007, 12:50 PM
PlayStation3 PlayStation3 is offline
sealed sounds better but ported is louder
Old 01-06-2007, 12:55 PM
Darrick147's Avatar
which type of ported box sounds better?
Old 01-08-2007, 02:29 PM
Lefix's Avatar
Lefix Lefix is offline
Send a message via MSN to Lefix
Well, basically your TRUNK is a sealed box, and having a ported box inside your "sealed box" would sound better, the sub usually tells you the recommanded size of box, and you can port it however way u want
My CarDomain
Boost coming soon...
Old 01-08-2007, 02:47 PM
No your trunk does not act as a sealed enclosure, the only way this works is if you make it a sealed enclosure for either a free air sub setup or for a set of speakers.
As for the ported slot ports are the best.
Cardomain
Old 01-08-2007, 05:32 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
well, the car itself is a sealed enclosure .... at least when al the doors, windows, etc .. are closed
Old 01-08-2007, 10:02 PM
Hence the reason for 1" think lexan for pure spl vehicles, and extra 100-200lbs of weight from sound deadening, or in some cases concrete.
Cardomain
Old 01-08-2007, 10:06 PM
Darrick147's Avatar
ok then how do u make a sealed box into a slot ported box easily?
Old 01-08-2007, 10:22 PM
Best way is to measure the volume and then determine what you want it ported to, then get the required amount of tube and drill the hole in the top and mount the tube.
Cardomain
