scanmaster 3 questions
So my next thing i want to get is the scanmaster 3.. it looks like it is the best out there for us first gen cars. being that it is in real time. now the problem that i am running into is that it plugs into the obd1 port and i used the jdm wirharness and it does not have any obd1 port or any diognostic port that i am aware of.. is there any way to bypass all of the signals?? make my own port of some sort? or any big problems you can think of?
Re: scanmaster 3 questions
I'm not familiar with the scanmaster 3, is it for data loging? There is some "free" software out there for the first gen, I might have it somwhere but I doubt it as I changed computers recently. I use a palm and plug into the OBD2 via my shiver cable (made and distributed by a guy on 3si called shiver).
1995 3000GT VR-4 Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup. Soon:Topline Engineering ground wires. |
Theres not a hookup under the dash on the right above the gas pedal?
no.. deffenetly not.. I have touched every wire on the front half of the car.. there is not one on here for sure..
Wierd, but I've only owned second gens.
Amazes me there isn't a diagnostics port...but I've never screwed with a JDM harness. Do you have a fuse box under the dash? It should be right there practically connected to it.
If not, if I understand you correctly, you still have the original 92 ECU (or at least some OBDI ecu, but the JDM harness) If you have the obd1 ecu in there, you are just going to have to splice a port in there somewhere. Reference for pins on port ECU pin diagrams Judging by that, it says pins 112 and 113 go from the ECU to the diagnostic port. 112 being MPI functions from ECU, which is pin 1 on the diagnostic port. 113 being the Query wire from ECU, which is pin 10 on the diagnostic port. So apparently those 2 come directly from the ECU. The rest will have to be spliced and I don't think the ECU changes the signal, so they should be able to be spliced in basically anywhere in between ECU and original sensor/unit. Now I say all that just by looking at the pin readouts. I havn't looked under my dash at it. Plus, how many of htem do you even need? For datalogging the engine, I would htink only the two above mentioned pins and a ground pin would be necessary. The other pins are for other systems like ABS, ECS, etc. So even if you never connected anything other than those two pins and the ground, you may still be able to datalog. Give it a shot...good luck.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Dude igo... you are freaking amazing! you have answers to everything.. so yeah there is a fuse box that is set up the exact way the usdm one is however it does not have the port.. and i am running on the jdm Ecu I have a hard time thinking that they are going to be much differant.. however my speed sensor would be in KMPH and i dont have 3 o2 sensors.. only 1... so yeah i guess there are some changes.. I think i am going to try running the car with the stock computer from the usa and see if it runs still.. if it does that would mean that all wires should be the same??
I reread what i said and it sounded like i was being an ass.. i didn't mean it that way.. I ment you really have answers for every thing!!
Add me on Facebook!! Add Me on Myspace!! I am on Twitter.com too!! add me as a freind on Digg!! check out CCOTM! Last edited by jason_bet; 01-12-2007 at 02:47 PM. |
Ok so i conected the jdm wire harness to the usdm computer and it started right up.. in fact it took off one of the lights on my dash? i dont even know what the light that was on was.. i will have to post a picture.. anyways so the jdm and usdm computers have to be almost the same...
Never thought you were answered like an ass. haha.
I don't think the wiring harness would matter at all. I mean it's only wires, no actual devices or sensors. So as long as everything is connected somehow you are good. If you have all the devices on one end connected, adn the ecu and whatever else on the other end connected...you are golden. Dash lights
Yeah i know what the dash lights are.. in the us.. they are not all the same in japan.. i will go take a picture right now..
![]() There is the picture.. i am guessing its the o2 sensor? maybe? it is the light on the bottem right |
