Old 01-05-2007, 10:36 PM
bogart1 bogart1 is offline
bogart1
My 98 caravan has a slight grinding or crunching sound on occasion...3x to be exact. Once while driving on the freeway it made the noise then slipped into neutral and stayed that way for about 5 minutes. Twice more it happened while parking. Any ideas? Also, while idling, the vans oil light dings. New oil pump? If so, how much$$? Thanks. The van has 163k miles on it.
Old 01-06-2007, 01:58 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: bogart1
Only way to make sure the pump is bad is to connect a direct pressure gauge to the system and read the pressure. Other reasons for the light could be low oil level, wrong viscocity oil, or low idle rpm. Cost would be $200-400.
Sounds like your transmission is beyond a fluid and filter change. I would let the pros look at it. Short of that go to Autozone and have them download any stored fault codes with a scanner. It's free. They can tell you what the codes mean. Drop the tranny pan and look for metal shavings. Change the filter and put in ATF-4 fluid. If you see shavings you'll need to have the tranny rebuilt or replaced. Welcome to the forum.
OBTW - The subject line should include something about the problem, not your forum name.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
