I was wondering if anyone has ever heard of Steel Seal. Its supposed to be a break through in coolant leakage from minor gasket leaks in the heads. I would like some input before i purchase this product. So help me out peeps. I have 2000 gp se 3.1
Re: Steel Seal
Your 3.1 is most likely leaking from a cracked plastic intake gasket, and no type of sealer will help. It is a very common problem on your engine, and the only fix is to change it.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Re: Steel Seal
I am not a firm believer in engine additives or so called miracle band-aid fixes but here are the claims:
http://www.steelseal.com/eng/home.html You'll have to be the judge based on your circumstances and budget. ![]()
Re: Steel Seal
What I am trying on my taurus when it comes in, I am not sold on it working but it seems in theory it will work.
The whole idea they give money back guarantee actually why i am trying it. |
Re: Steel Seal
You asked about Steel Seal. this stuff real works. I have a 2003 F150 Supercrew, with a blown head gasket back in 2009 Checking around with the different mechanics, I was quoted $2500. I just could not afford it. So I started looking on the internet for a solution. I checked out Steel Seal, watched the video and was convenced it should work for my problem. Here it is December 30, 2013 and I have not had any more problems since. I highly recommend the stuff.
Re: Steel Seal
I can tell you that I learned a valuable lesson, check the oil, and get it changed as recommended.
