Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-05-2007, 06:13 PM
Coachbigb Coachbigb is offline
94 Camaro won't start ... dead
This car was bought in June of 06 and we have had no issues. Today while I was driving the car it simple went dead. Like when the electronic ignition fails. I disconnected the Positve cable and waited 5+ minutes and reconnect and car started. An hour or so late it went dead again and remains that way Could the computer be failing and putting electonics in a safe mode and not allowing to start? The car is my sons and this Marine wants his car back.
Thanks
Old 01-05-2007, 07:43 PM
SG007's Avatar
SG007 SG007 is offline
Send a message via AIM to SG007
Re: 94 Camaro won't start ... dead
Is it throwing any codes? It's definitely electrical though if it just cut out. When you try and start it does it turn over or anything?
-2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*-
Old 01-16-2007, 09:32 AM
MykeDee MykeDee is offline
i had this same problem with a 98, it was the ignition module. about $70 and not hard to change...
i had gotten the spark plugs changed about 2 or 3 weeks earlier, then it it just shut down going down the road, it cranked once after messing with the spark plug wires and made it to the store and back and never cranked up again, about 3 months later, i changed the ignition module and it cranked right up...just an idea, im no mechanic
Old 01-24-2007, 04:37 PM
scoobytuff scoobytuff is offline
Does your car have the transponder key. On my 94 the wire that goes to the lock cylinder had a bad connection. I replaced that and it was fixed. The car would start when it wanted to very un predictable.
