Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 01-05-2007, 04:46 PM
kmarajh kmarajh is offline
Question Passenger door lock died
Passenger side door lock no longer works with remote or door mounted switch. All others work as usual.
Anything I should know before I dive into the door ?
Is this a common issue, known fixes?
thanks alot.
Will be putting up for sale very soon, new car came in this week.
01 LSV6
Old 01-05-2007, 05:47 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Passenger door lock died
Seems that the first suspect would be the door lock motor. When you get the door apart, you can check the voltage to the motor when the lock/unlock button is pressed. Also, if the lock motor is open circuit, that will be a hint of a bad motor too.
-Rod
