Fog lights on '01 Suburban won't work
Hey guys, I've bought a 2001 Suburban about a month ago. Everything's great except I can't get the fog lights to work. I believe I've checked all the fuses and relays, changed the bulbs and it still won't work. The little light below the fog light switch doesn't come on when you push the switch. Any ideas? The only thing I can think of is either a bad switch - which doesn't seem likely, does it? - or maybe whatever tells the fog lights that the hi-beams are on or off isn't working properly. All the connections are good as far as I can trace. Anybody have any thoughts on this?
Thanks a ton! |
Re: Fog lights on '01 Suburban won't work
Fog lamp relay is controled by the BCM.
The switch sends a ground signal to the BCM and then the BCM commands the fog lamp relay
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
I don't understand. What is the BCM?
Thanks |
Body Control Module
I tried a friend's switch that I know works and it didn't help anything, so it's not the switch. I took it in for diagnostics and they said the BCM isn't recieving a signal from the headlight switch that they're on, so the fog lights don't know the headlights are on and they won't work unless the headlights are on. Got any ideas about what might be the problem or maybe how to bypass the BCM? I believe I've checked all the connectors in the line and everything seems good. Bad wire? I don't know.
