Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-05-2007, 02:40 PM
wings_ky wings_ky is offline
vibration problem
I having problem with my front axle, when i speed up to around 60 and let off the gas there is a loud vibration and noise coming from my front end, i though it was the tie rod, so i had it check and replace, i also had the rear bearing and axle replace. But the vibration didn't go away, I was wondering does anyone know what could have cause this.
I looked under the car the other day and notice that a brakect is just hanging there, i not sure where it go though, I think i is mounted from the tranmission to the axle but not sure either?
I drive a 96 Eagle Tsi AWD
Old 01-05-2007, 04:12 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: vibration problem
The hanging piece sounds like the problem. At least that's the first place to start. Take it in to see what it is. Maybe take a pic and post it up. Sounds like maybe a tranny problem however. Where is this bar coming from?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-05-2007, 05:49 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
i had that same problem before i sold my rs, and i'm thinking it was the brearings(sp)? you know the bearings that go in where the front hub is. am i being specific?
well here's a pic
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 01-06-2007, 09:58 AM
I took it to midas and they told me that my tie rod and my rear bearing was going out so i had those replace but when i run it from 0 to 60 it would be fine until i let off the gas, but the vibration would continue untill i reach a low speed then it would stop. could this be my front wheel bearing or something else.
Old 01-06-2007, 10:45 AM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
try to go someplace with a wide open area, or like a long empty expressway, and get up to 60mph or so, and then jerk the wheel to the left or right quickly, but safely, you know what i mean? not enough to spin out the car or anything lol. usualyl if its a bearing in the front, the noise wll go away if you turn a certain way, therefore putting more stress on either the left or right side(more stress or relieving stress?). i think the rule of thumb is, if you turn hard left and the noise goes away, its your right side bearing, and vice versa.
i have the same problem, except the noise is there from about 30mph, and gets worse up until 60mph, and then i can barely hear it after that. im just gonna say its road noise lol.
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
Old 01-06-2007, 01:57 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
I would make sure and rule out the obvious things first, like get an alignment and balance the tires. Also, have them check and make sure you don't have a bent rim.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 01-07-2007, 12:10 PM
well i went under the car the other day, and saw that the bearing bracket is hanging there, i think that might be the problem, but i an not sure, also the bolt on the bracket snaped off half way in the hole where it is mount, does anyone know do i have to drop the whole tranmission to redrill out the hole and tap it, or is there another way?
The bracket bearing goes on the axle to the tranmission, on the left front side.
Old 01-07-2007, 01:26 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
The bracket that's hanging down is the axle support? If so, then that's whats causing all your problems and if you drive it anymore like that, you'll be replacing that axle too. You should be able to take and drill a hole into the bolt and use an EZ Out to get the bolt out.
95 Talon TSI AWD
97 Eclipse GST
