Go Back   Automotive Forums Car Chat > Car Buying Q&A
Car Buying Q&A Ask a question, get an answer; it's that simple. Visit AutomotiveHelper.com for useful car buying tools and research.
Old 01-05-2007, 03:16 PM
Rememberme Rememberme is offline
Question Cam Belt vs Chain Driven
Which is the best to buy? Cam belt or chain driven cars? How do I know which are which? Is there a website that will tell me that? Thanks.
Old 01-06-2007, 12:20 AM
PlayStation3 PlayStation3 is offline
Re: Cam Belt vs Chain Driven
there is no real total difference now a days. the difference mostly is the service intervole is different. roughly 70k for the belt and 100k for the chain. most cars use the belt, saturn and a couple others still use chains
Old 01-06-2007, 04:04 AM
Thanks. Umm, does that mean the chain needs replacing too and is it likely to be similar in cost to do so?
Old 01-06-2007, 09:16 AM
yea the cost is pretty much the same.
Old 01-06-2007, 12:59 PM
Thanks, this helps me a lot in the choosing of a car
Old 01-06-2007, 01:14 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
A lot would depend on the year make and model and engine.
Some belt replacements are cheap and some can get expensive and some if the belt breaks it can bend valves and blow engine.
Some cars belt or chain the water pump is driven with the belt and chain another thing that may have to be replaced.
For example A 98 chev cavalier 4 cyl 2.4 engine the timing chain has to be remover to change the water pump.
I just changed the water pump on one at 108911 miles.
With a new water pump and new timing chain over 600.00$ US parts and labor
If it has a belt always follow the manf. specs on belt replacement.
Good luck
MT
Old 01-06-2007, 01:41 PM
Good luck
Cheers, thanks for this info.
