Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-05-2007, 09:08 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Transmission Bolts?!?
My old transmission was apparently taken in and out too many times... The bolts that fit it, will not fit the new one. The old transmissions bolts are too big in diameter...
Can anyone tell me what size bolts I need to buy for the transmission mount (2 bolts, on the engine mount for transmission)... I need to know by 5 this afternoon, parts are supposed to be in, going to pick them up and reassembly will hopefully continue tomorrow...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 01-05-2007, 09:48 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Transmission Bolts?!?
Make year and model would help.
But from what you described One trans may be metric and one SAE bolts.
You may have to get both and use the one that fits.
Good Luck
MT
MT
Old 01-05-2007, 09:55 AM
Mikelb's Avatar
Good Luck
MT
Sry, that info was in my Sig...
1991 Eagle Talon Tsi (FWD) 5-speed...
The new transmission I b/l is from a 1990.
Old 01-05-2007, 10:12 AM
MT-2500's Avatar
AF - Advisor
Sorry I missed reading the sig.
It sounds like one is metric bolts and one is SAE bolts.
Good luck
MT
Old 01-05-2007, 10:28 AM
Mikelb's Avatar
it's all good... I should have stated that the car was listed in sig... I'll take the bolts I used in the first and buy some a few steps smaller, and return the one's I dont need (if possible)...
Old 01-05-2007, 10:36 AM
MT-2500's Avatar
AF - Advisor
You may have to select fit to get the right bolt.
If you have some old bolts laying around see it you can find one that will screw in .
Also check the hole depth with a small screw driver or slim measuring stick.
Do not get one to long.
Measure hole depth with a small screw driver.
Find a parts place with a good selection of bolts and see if you can match anything up.
If your old bolts are to big get a smaller one in SAE or metric or both and try them.
Good luck
MT
Old 01-05-2007, 12:38 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
99% of the bolts on these cars are metric. I know some use 19MM sockets, and some use 17MM sockets, it that helps at all.
95 Talon TSI AWD
97 Eclipse GST
Old 01-05-2007, 12:55 PM
Mikelb's Avatar
I knew that much... and that's how I know that the bolts on the old one weren't correct, I think they were either a 21 or 23...
What I need to know is the diameter, length, and thread pitch...
Old 01-05-2007, 04:14 PM
The thread pitch should be the same, and the lenght, just get something close, and then just get a smaller/bigger diamater for what you need.
95 Talon TSI AWD
97 Eclipse GST
