Old 01-05-2007, 05:17 AM
laneet88 laneet88 is offline
Send a message via AIM to laneet88
Check Engine light, No speedometer
i have an 89 civic hatchback dx
the car will start fine
the first immediate problem is that the speedometer will not work at all
and about 20 minutes later the check engine light will come on
i havent checked the ecu code yet but i read somewhere about a vehicle speed sensor error that could possibly give you the check engine light. i was wondering exactly what that is and if that would make the speedometer stop funtioning.
if that might be the problem is it an easy fix?
any help is greatly appreciated
thanks
edit: i checked and the speedometer cable was loose so i plugged it back in and the speedometer works again. it doesnt seem likely that that would be the reason for the check engine light though.
could that cable being loose cause the check engine light to come on? it only started coming on the exact day the speedometer stopped working.
tomorrow i might take it over to a friends who lives a little ways out and see if the check engine light still comes on. unless someone gives me other advice. i guess if it comes on again the best things to do is check the ecu code.
89 Civic Hatchback - Pretty much stock minus the paint and Acura rims
Old 01-05-2007, 07:57 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Check Engine light, No speedometer
Speedometer popping out of tranny is Code 17. Just undo the 15a ECU fuse from the under hood fuse box for 30 seconds and put it back and this will reset the ECU causing the CEL light to go away.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 01-05-2007, 10:40 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
FYI, when your speedo doesn't work you can drive away fine. after you exceed 3000rpm (it might be 3500) and then let the rpm's drop.....say when you shift, that is when the light comes on.
do as mentioned above or the code is stored in the ecu. next time you get a check engne light it will flash for the current & old problem
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 01-05-2007, 06:56 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
that is true^.
-tony-
2000 honda s2000
Old 01-05-2007, 11:19 PM
oh thanks for the information.
it was really helpful.
Old 01-07-2007, 10:16 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Yep, just reset your ecu and the light should go away. It stays stored in the ecu until like 60 miles after an apparent problem has been fixed.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
