Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-04-2007, 11:55 PM
mikey29 mikey29 is offline
Send a message via MSN to mikey29
help 96 bonneville
i noticed this screaching and grinding noise on the right side front of my car when i hit 40 mph or higher and when i drop below 40 the noise goes away could anyone please help me with this problem i was told it might be wheel bearings but would like some more imput
Old 01-05-2007, 06:42 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: help 96 bonneville
Welcome to AF!!
There are a couple of possible causes. One of the causes is a wheel bearing going bad. But a far more common cause is a worn out brake pad. The wear sensor on the pad will contact the rotor and make the noise you are speaking of. I would pull the wheel and check the brakes first before I went to the expense of changing a wheel bearing.
