Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 01-04-2007, 05:33 PM
HeWhoKillz HeWhoKillz is offline
1982 98 won't start
I got an 82 98 olds and now it won't start. It will crank once or twice but its like it ain't got enough power to crank itself anymore. The battery is only two months old. Anyone know what could be wrong?
Old 01-04-2007, 06:40 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Arrow Re: 1982 98 won't start
Have you checked your battery voltage, it should have 12.5+Volts with a full charge. Be sure to check both battery cables for corrosion, if found, clean and reinstall. If the battery & cables check out, then I would suspect the starter.
BTW, if your battery is low, you need to check the alternator output!
Old 01-04-2007, 06:42 PM
How would I know if its the starter? It wouldn't be the carburator would it?
Old 01-06-2007, 12:52 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
If you have 12.5+ volts on the battery,
and its not turning over then I would suspect the starter is bad.
If you remove the starter most parts store will test it for you on thier machine for free.
Also check the starter wires first,
if they are loose it wont work very well.
1999 Grand Am SS 3.4 OHV
Old 01-08-2007, 10:12 PM
Well, we got it to start. It just misses really bad. We dumped so gas down the carburator but it misses terribly and struggles to stay running while the car doesn't have the gas pedal depressed. I guess it can't be the starter now. What would make a car miss so bad that the car wouldn't stay running very well?
Old 01-08-2007, 11:25 PM
Several things could cause the car to miss.
The carb out of adjustment, ignition system, short in the wiring, fuel contamination .....
