Old 01-04-2007, 12:30 AM
mechhound mechhound is offline
any transmission experts here?
My son has an '89 Taurus sedan 3.0 engine, AXOD transmission. For a while when he first started it he had to shift to reverse and then drive, then it worked normally. Tonight he sucked out some transmission fluid and then added some of that fancy transmission additive that is supposed to improve shifting. He then made about a two mile round trip and returned to his yard. Now the car won't engage in gear at all. The tranmisson was not slipping or anything previously. Any ideas what the problem may be?
Old 01-04-2007, 04:41 AM
Millermagic Millermagic is offline
Re: any transmission experts here?
It's toast. If you think the car is worth it - rebuilt or get another one from somewhere
- Leather - Transmission Cooler - Gen III Tweeter Sails - Gen III Rocker Covers -
As you walk through the valley of RICE, you shall fear NO V-TEC, for torque is with thee!
Old 01-04-2007, 07:01 AM
Scrapper Scrapper is offline
AF Premium User
Exclamation Re: any transmission experts here?
i'd say rebuild tranny..i would change fluid and filter first tho it's cheaper..then you'll know and check for medal shavings....good luck....
SCRAPPER...
Old 01-04-2007, 10:41 AM
Huney1 Huney1 is offline
Take it to a tranny shop and ask them to drop the tranny pan and check the screen for shavings or debris and I think they can do a flluid pressure check. That way you'll know for sure 'cause if the tranny fluid wasn't changed for a long time it gets funky and can cause problems. If nothing unusual on the screen or in the pan sump maybe a $60. fluid change will solve the problem but if it needs a rebuild then you're looking at $1,500. or better.
If that be the case, sharpen your pencil and figure how many miles on it and remaining life expecentacy and best rebuild the tranny or junk it for parts and get another ride. Good engines in the Tauri and if you take reasonable care of them they go $200K mi or better no sweat.
