Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-03-2007, 09:30 PM
Chrispyski Chrispyski is offline
Windshield Wiper Parking Problem
For just over a year my windshield wipers ('95 Crown Vic) have been acting crazy, parking themselves in the full, upright position sometimes, stoping right where they are other times. They operate normally when turned on, but park themselves randomly when turned off.
I've never had this problem before so other than the obvious checking of fuses, I'm stumped. I've gone a year with this problem, but since I live the the NW and it rains alot, its getting rather irritating.
Any help anyone can offer would be GREATLY appreciated, Thanks.
Old 01-03-2007, 10:15 PM
cvpi guy cvpi guy is offline
Re: Windshield Wiper Parking Problem
i know ford had a recall for some if not all CVs for the wiper motors control unit so you may want to contact your dealer and ask if the recall was avail for your car and if its been done
hope it helps
Old 01-04-2007, 09:04 AM
sheebeehuh sheebeehuh is offline
It's quite possible that it's the multi-function switch (MFS); the stalk on your steering column that turns the wipers on and off. They are known to go bad and can cause the wipers not to park correctly (among other things). They are relatively straight-forward to replace and should cost less than $100.
That's where I'd look first...
Old 01-04-2007, 08:30 PM
Yeah, I forgot to mention but it was an old fleet vehicle, so I assume (perhaps too much) that they took care of the recall issue.
Looking at other peoples problems with the wipers on this car I'm presuming that it is the multi-function switch. While their problems are not exactally the same as mine, it seems to be most likely problem.
Thanks cvpi guy and sheebeehuh for all your help!
Old 01-05-2007, 05:20 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
99% of the time if the wipers are stopped in the upright position, the wiper motor park circuit is at fault. Replacement of the wiper motor cures it.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-05-2007, 06:09 PM
hmmm, now thats got me thinking.
I can remember excatally that things started malfunctioning after a big storm and the wipers had been on the fastest setting for around 2 hrs. A circuit makes more sence in this scenario.
Thanks for the help way2old, from looking at this message board you are quite wise when it comes to these things. That will be the first thing (and hopefully for this problem, the last) I replace.
Old 01-08-2007, 10:35 PM
jabhawk jabhawk is offline
I had the same or similar problem with my 93. The arms would run fine but when I went to shut them off they would slowly swing up to the vertical position.
The wiper motor/transmission was the problem. The gears were worn and would not hold the arms down.
Had to replace the whole assembly on the cheap. The mechanic got a rebuilt unit from a junkyard and dropped it in for $110 total. he had the dickens of a time getting it to syncronize correctly. Working ok for last 8 months.
Jon
Old 01-09-2007, 07:42 AM
reekor reekor is offline
A rebuilt unit from a junkyard? Is that something like buying a new used car?
Jon
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 01-10-2007, 12:00 AM
Ha Ha. No it is like saving $150 on the repair.
