Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 01-03-2007, 06:45 PM
accord_rokr accord_rokr is offline
05 Neon Rediculously bright lights!!
Ok, so my wife's dad bought her this brand new 05 Neon early this year. Her mom took it and wrecked it, and after it was fixed, it seems to be running with a miss; gas seems to be ill consumed, and nothing is in disarray...
Air Filter... clean!
Plugs AND wires... JUST replaced them 250 miles ago.
oil... immaculate! not 1500miles on it...
there is no distributer...
runs and cools normally...
what is it?
Also, after this accident, the lights seemed to appear retardedly bright to oncoming drivers and drivers in front. But they're on dim! Bright seems to have no brighter affect, hi and lo are about the same illuminocity!
What is it?
Old 01-03-2007, 07:57 PM
sheetmagnet sheetmagnet is offline
Send a message via Yahoo to sheetmagnet
Re: 05 Neon Rediculously bright lights!!
Well people don't seem to want to reply to posts anymore like they used to, so I will answer both of your questions:
As far as the "miss," is it a ticking sound? Or is the motor literally shaking and not even igniting on one cylinder? If I had to guess, I would say it's just a lifter tick on the driver's side, where oil and lubrication is sometimes tough to do on cold starts on the 2.0l.
As far as the headlights, the wreck probably knocked the headlights out of alignment. From the factory your headlights are directed down the road and slightly to the right of oncoming traffic, and are supposed to "land" on the roadway about 100-150 ft from your car. When you turn on your brights, the light is more focused above the roadway. Well, it sounds like your headlights are now pointing out above the road or into the sky on dim, and way out into the sky on hi-beams... if this is the case, your dims will blind oncoming motorists because they are focused straight into their eyes like hi-beams, and your hi-beams will just get dispersed into the sky even more (and make it seem like they are not brighter, but actually are... just not shining on anything in the sky).
...go ahead and throw your $10,000 spinner-rims on your gas-guzzling Explorer... in my Neon's rear-view mirror, they look just like the rest of your ride: MOVING BACKWARDS!
Old 01-04-2007, 01:31 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
what is it?
What is it?
Any check engine lights.
As said head light adjustment or check on the headlight aiming and hold downs.
Also you might check the engine running battery voltage.
Run away voltage could give bright lights and engine running problems.
MT
