Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-03-2007, 05:09 PM
hurd1204 hurd1204 is offline
window problems
3 out of my 4 windows dont work in my 1997 jeep grand charokee.. what could this be?
Old 01-05-2007, 07:53 PM
hulkmn069's Avatar
hulkmn069 hulkmn069 is offline
Re: window problems
bad wiring connections, bad switches, and the most expensive bad window motors. i've already had to replace a motor in my 99 and a switch has gone bad too good luck.
Old 01-06-2007, 01:07 AM
martola martola is offline
Send a message via Yahoo to martola
Wink Re: window problems
I'm pretty sure your problem is in the drivers door wiring bellows( the rubber boot between the door & the body) I see lots of these, pull back the boot,& I'll bet you find a broken wire in there There is a drivers,& passengers door module & this wire if broken will take out the passenger front,& both rear doors,Fix it & you should be fine.
Martola
