Old 01-03-2007, 05:06 PM
junker2 junker2 is offline
Exclamation 1991 C/K 1500 Fuel Pump problem
Truck won't start, traced problem to fuel pump, further inspection shows no voltage to the fuel pump, put new fuel pump relay on and that did nothing, what else could be wrong and where can it be found/what needs to be done? Thanks in advance.
-Junker2
Old 01-03-2007, 06:46 PM
maxwedge maxwedge is offline
A990 racer
Re: 1991 C/K 1500 Fuel Pump problem
Welcome to AF. Fuse good, can you power the pump from the jumper connector near the relay panel?
Old 01-03-2007, 11:04 PM
homefree's Avatar
homefree homefree is offline
Rusted out ground wire that connects from the top of the tank to the frame, or broken ground wire at tank.
Old 01-04-2007, 02:26 PM
Fuse is good, replaced and re-grounded the ground wire on top of tank, where is the jumper connector near the fuel pump relay panel/what does it look like?
-Junker2
Old 01-04-2007, 06:24 PM
butch h butch h is offline
When I have electrical problems & there is any doubt of ground,I run a wire to the battery ground terminal,then I know that a failure to find power in a given situation is because there IS no power there.
Old 01-05-2007, 10:20 PM
tec5120 tec5120 is offline
could be the fuelpump fuse under the cover next to fuelpump rely on the pass side firewall.does the gas guage work?
Old 01-16-2007, 01:53 AM
zario zario is offline
what size engine do you have? that I know on the 454 models when you have a bad oil pressure sensor or oil sending unit it will have a short and will effect the fuel pump it will cut the power or will leave it on, it sounds dumm but my friend just had the same problem and I couldn't believed know I'm not sure if it's the same for the others
Old 01-16-2007, 12:58 PM
bigj-dog's Avatar
bigj-dog bigj-dog is offline
I've seen a rash of worn out ignition switches in recent months, check the schematics for the power wire to the pump at the column. The last one I did was a '91 1500. It would run the fuel pump, but only when the engine was cranking or running, it wouldn't give it that 2-3 seconds primer charge.
