Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 01-03-2007, 01:50 PM
Frank E Frank E is offline
HVAC lights INOP
Hi there...I have a 2002 Jetta GLS 2.0L automatic with a sunroof...all dash lights are working exept HVAC control lights. Is this bulb or could it be fuse?
The reason I suggest maybe fuse is because none of the HVAC lights are working. Are they all lit by the same bulb?
If it is bulb, could someone describe to me how to replace the bulb.
Any and all help is much appreciated.
Old 01-03-2007, 09:12 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: HVAC lights INOP
there all lit by one bulb.
1) remove the center knob with a pliers (make sure its on 0 )
2) use a 1/4" vacuum hose and push it on the bulb and pull out
3) put new bulb in the hose a little and push in the socket and twist and pull out at the same time to get the bulb to stay
Old 01-04-2007, 09:14 AM
Thank you. I will give this a try. Info much appreciated.
