Old 01-03-2007, 01:45 PM
bedpan bedpan is offline
coolant temp sensor
I had to replace the cooling lines for the transmission on my '94 PA.
To access the lower line at the radiator, I attempted to unplug the temp sensor to the radiator and instead the whole sensor came out, spilling coolant all over the place. I got it back in but now when the radiator in under pressure it pops out. I can't drive the car. Is it possible I may have lost some kind of O-ring, should I replace the sensor or did I break something on the radiator?
Help
Old 01-03-2007, 01:57 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: coolant temp sensor
I would imagine the sensor is threaded into the radiator. Given the amount of heat is subjected ot either the threads o fthe sensor broke off or the vice versa in the radiator.
Old 01-03-2007, 02:34 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
How do the threads look on the sensor? Try wrapping the threads with teflon tape and tighten the sensor back in there.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 01-03-2007, 03:22 PM
This doesn't seem to thread in, it just pops in. Maybe it's not a temperature sensor. It is on the passenger side of the radiator right by the battery, about midway down. The upper cooling line for the tranny runs right next to it. It is all plastic and pops into a receptor moulded right into the radiator. No threads anywhere. Maybe it's a low coolant sensor but I thought that would have been on the reservoir not the radiator.
Does it seem odd that I was able to replace the cooling lines myself but I don't know what this thing is called?
Old 01-03-2007, 06:08 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
What you are referring to is the “coolant level sensor”! It should have a retaining clip on the sensor and when pushed in, it will clip onto the little neck on the radiator. It sounds like the retaining clip broke off. You will need a new coolant level sensor! Most national part stores keep them in stock.
Old 01-03-2007, 06:12 PM
Ahhhh!!.....
Thank you very much.
Maybe I can get my wife to just stick her finger in it while I drive around.
Old 01-03-2007, 06:30 PM
HotZ28's Avatar
AF Moderator Elite
Hey, I like the wife idea! Have you talked with her about doing that? Here is a pic of a 94 PA "coolant level sensor". Does this look like what you broke?
BTW: That is a Standard Products part #FLS15
Old 01-04-2007, 09:41 AM
Yes, that is it, but mine no longer has the retaining clips, hence the problem.
$31.99 for such a small part but a small price to pay to keep from overheating.
Thanks again.
Old 01-04-2007, 09:44 AM
wrightz28's Avatar
Originally Posted by bedpan
Ahhhh!!.....
Yeah but then you get that annoying squealing noise, kinda like when I speed past the shopping mall entrance and a squealing noise starts coming from the passenger side front seat area
HotZ28,
You know, I'm blowing up component locaqtor, I searched it for anything cooling system realted and nothing but the ECT came up for '94
Old 01-04-2007, 11:11 AM
Yeah....I found a few sites that didn't list this item at all and a few parts strore in my area that had to order it and wanted to make me wait 4 or 5 days.
Found it this morning at Checker Auto.
Finally got my wife to get her finger out of the radiator and then I just left her there.
Old 01-04-2007, 07:27 PM
Loekee75's Avatar
The coolant temp sensor should be located inside the driver side of the intake manifold; the coolant level sensor is located in the radiator. Note that not all models came with a level sensor; it was an extra option to have a "LOW COOLANT" warning. Some radiators simply had a pet cock where the sensor would normally go.
