Old 01-03-2007, 01:39 PM
mcqueary mcqueary is offline
93 Lesabre Pinhole leak in tranny cooler line
Just noticed this leak yesterday when I had the car idleing in the garage for a period of time. It leaked about half a cup of transmission fluid in about 30 minutes of idleing. The hole is about 2 inches from the transmission connection in a U-curved portion of the metal line. At first I suspected the connection but upon close examinantion it is the line itself that is leaking. It's a small hole and does not leak when the engine is not running. It only leaks when under pressure. I suspect the leak will get worse with time if left unattended.
Is it possible to repair this metal line and if so how? I believe the fact that its not in a straight section of line may complicate things. Or should I just get new lines?
Thanks,
Tom
Old 01-03-2007, 02:17 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: 93 Lesabre Pinhole leak in tranny cooler line
The best thing to do is replace the line all together. I have tried on numerous occasions to repair tranny lines on many of my vehicles over the last two decades and have come to the realization that in the end, replacing the whole line is usually the best solution. Living in NY where they use a lot of salt really corrodes tranny, brake, and fuel lines. It has become a regular event for me to try to fix the lines only to have them leak in another location, or have the repair fail later on. A quick fix would be to replace the leaking area with a small piece of hose and hose clamps. I used to use two clamps on each end of the repair as the lines are pressurized and I seem to get a better repair when more clamps are used. This should only constitute a temporary repair until you can replace the entire line. New lines are generally available at your local parts stores. Get a new one a little longer than the original and take your time bending the line to achieve the best fit without crimping the new line.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 01-03-2007, 02:49 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
If you can pin point the leak source, clean the surface with some fine grit sand paper and patch the affected area with JB Weld. It hasn't let me down yet! It especially works well on metal, as I repaired a huge (2in x 1/4in) gash in a gas meter with the stuff. I've used it on several radiators, too. I have no doubt in my mind that it'll work for your transmission fluid leak as well.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 01-03-2007, 03:45 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Note to self: no smoking in Loekee's car or around his house, check
I've used JB weld on exhaust welds that have cracked and been pretty satisified, even on one occasion patched up a intake manifold crack with it. But something pressurized with hot liquid in it or worse, something flamable
