Old 01-03-2007, 10:21 AM
diractinc diractinc is offline
94 Silverado headlight problem
I have a 1994 Silverado 2500 6.5L diesal and I am having trouble with my driving lights. When I start the truck my running lights go on and I am able to use my park lights, but I can't use my driving lights (high or low beams). In fact some times when I try to turn on the driving lights the running lights will quit. I was thinking that this may be able to be fixed by changing the DRL light relay, but I don't know where this is and I have too little experience with electrical problems to really know if this is a good guess. Any help with this problem would be appriciated.
It is also stinkin cold here (don't go to canada in the winter) and both the driving and running lights don't seem to work well when it is below -15 C (~5 F).
Old 01-03-2007, 07:16 PM
777stickman 777stickman is offline
Re: 94 Silverado headlight problem
I don't know about your '94 but the on my '98 Sub only the low beams go thru the DRL relay which is located in the "convenience center" bottom center position. The "CC" is just forward of the park brake pedal on the inside firewall.
Just from your post I would suspect the light switch or the "multifunction switch". Also make sure your battery and ground connections are good and clean......Steve
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 01-05-2007, 01:53 AM
Thanks stickman, I changed the switch and it corrected the problem
Old 01-05-2007, 06:55 PM
Good job and thanks for posting back..........Steve
57 Chevy 210
