Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 09-22-2002, 10:56 PM
djhornsby djhornsby is offline
Send a message via Yahoo to djhornsby
Question lights on rack
Hey everyone, I need some help please. I have 4-100 watt lights to
put on my rack. I need to know what size wire to use what size relays
and how many to keep my x from melting? thanks allot!
Old 09-22-2002, 11:40 PM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
Try a search here. I posted a table with wattage vs wire gauge about a year ago.
Xterra4x4.com and the Xterra Offroad Webring
Old 09-23-2002, 11:22 PM
thanks for the reply but I checked and couldn't find the comparison chart
Old 09-24-2002, 10:52 AM
XTerra Guy
Methinks, you need to learn to use a search engine better.
I typed "wire" into the search window found at the bottom of /xterra/ and it came up. A search using the "main" engine at www.automotiveforums for "wire" and user name "Schludwiller" would have gotten a more narrow result.
Regardless here it is:
http://www.automotiveforums.com/vbul...highlight=wire
Old 01-16-2003, 05:08 AM
AerialViper AerialViper is offline
Send a message via AIM to AerialViper
Smile
DjHornsby,
I have 4 100 watt aircraft landing lights on my xterra and I used 12 gauge wire. I have had them on the xterra for quite a while and have had no problems. FYI...the equation for figuring out total amps from your lights is watts/volts. (IE: Amps = watts / volts) Just make sure you don't exceed your alternators output because then you will have problems. My 4 lights run at 33.3 amps total when they are all on. I have a relay with 2 fuses that are 20 amps a piece and have never blown the fuses. I have more lights than just the 4 100 watt lights. They all work great and no problems at all with any of them. Good luck!
AerialViper
Old 01-27-2003, 05:42 PM
thanks for your help viper.
