Old 01-03-2007, 03:12 AM
accord_rokr accord_rokr is offline
90 Accord Error code 43 WTF mate?
Ok, so I have a major problem here...
I have an error code 43, and it is eating my system up!
First it ate my Fuel Regulator, I replaced...
Second, my fuel pump, I replaced...
Third, I replaced my filter, hoping that this is my last step to turn the light off. (Negative battery terminal is d/c during installs, so the computer each time resets)
My light stays constant, I drive for a few minutes, and it comes on like clock work.
I replaced the filter and then a couple days later the filter starts spraying gas EVERYWHERE!! (word to the wise, DON'T BUY PARTS AT AUTOZONE!!!) I could have exploded!!!!!!! It sprayed gas all over my engine!
Anyhow, my car still has grab me gotcha, but it sputters a little everytime I let off the gas, and sometimes when I am starting off...
I'm thinking, my injectors? Any ideas? I need help! I'm poor! I need to know what the hell it is!
I guess I didn't make myself clear on the fuel system failure. I know that 43 is fuel supply system. I have all the codes, but I still after replacing all these things, have to deal with whatever is failed. I don't have any idea what the last step is other than trying "jeffcoslaker's" idea...
I am pretty sure it is my injectors, because I am getting a fuel backpressure causing failure on all my vital fuel delivery components...
Surely someone that has a 90-93 has had this problem!
I have to fix this! Before beating 6 cylinders was a breeze! NOW IT'S A CHALLENGE!!! It's embarassing!
Old 01-03-2007, 02:31 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 90 Accord Error code 43 WTF mate?
I had to look that up...code 43 is fuel supply system fault, yes?
I'd try wiggling the wires to all the injectors while it idles, see if you can get a stumble out of it...check all harness connections and grounds also...
Old 01-03-2007, 06:27 PM
thanks for that info, I'll have to try that when I get back to my car. Nothing was run over or affected recently, so I don't know if grounds just go bad or what, but I'll try that...
Code 43 is Fuel Supply System Failure, yes.
I'll post the outcome.
Thanks!
