Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 01-02-2007, 07:19 PM
gizeye gizeye is offline
?creeking noise when turning (into driveways)?
everytime when i slow down and start turning into a driveway (no matter the ground level), i hear a creeking metal bending noise... wtf is that?
the 240sx i bought hasnt been driven in 2 years, but the turning noise didnt start until 3 months after i purchased/driven it..
if it matters, i need an alignment and to change my brake fluids
Old 01-02-2007, 07:22 PM
HoosierDrifter's Avatar
HoosierDrifter HoosierDrifter is offline
Re: ?creeking noise when turning (into driveways)?
mine is doing the same thing... sounds like its comming from the rear subframe... but i just installed subframe spacers
71 Camaro RS/SR'ed 92 240sx
Old 01-02-2007, 07:46 PM
smoke78 smoke78 is offline
they should do it, but have then check the balljoints when they check the allignment. mine was doing something sounds about the same only much worse (mine did everytime i hit a bump but it did not start out that bad i just let it go to long) turns out that is what it is, the new balljoints cost about 50 buck.
Old 01-02-2007, 08:26 PM
zauber zauber is offline
Send a message via AIM to zauber
balljoints, lower arms, or axels. really anything around that area can do it...
in construction: s14 sr20det in my 91' coupe se
Old 01-04-2007, 06:29 PM
can you give me your opinion on how to fix/check/change this?
