Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-02-2007, 06:28 PM
that_guy5's Avatar
that_guy5 that_guy5 is offline
cylinder head
ok i got 98 civic and it overheats but i tried to look for a leak and couldnt find it i told ppl from work and they said that i could have a crack on my cylinder head is this true or was the guy bs me ??? but if i do have to replace it how much would it cost to buy a rebuild one??
thanks
Old 01-02-2007, 08:26 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: cylinder head
Do you mean that it keeps loosing coolant but you don't see a leak? It's probably a head gasket however it could be a cracked head or block. Gasket is a relativly easy fix. If it is the head or block you can find them here in the classifieds or on Ebay.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 01-05-2007, 11:18 AM
that_guy5's Avatar
Re: cylinder head
but if its the head gasket doesnt white smoke suppose to come out of my exhaust cause its normal color on mine right now
Old 01-05-2007, 11:30 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: cylinder head
Do a compression and leakdown test to make sure that its the headgasket and not the head itself. You may have to take the head into a machine shop in order to find out whether or not its ok.
Also, i would NEVER buy parts for my Honda off Ebay. If you aren't already a member of Honda-tech, become one and search the classifieds. There are more Honda parts there than any other source on the internet...
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 01-06-2007, 11:13 PM
toussaint_89 toussaint_89 is offline
Re: cylinder head
ok got a question i bought a d15 jdm engine and when i got it it was a d15 v-tec E and i have to change the block of my d16y8 out cause the block cracked. would i lose hp if i took the block from the d15 v-tec E and used my D16y8 head
Old 01-08-2007, 08:46 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
Re: cylinder head
make a new thread please.
-tony-
2000 honda s2000
